transfer pc-> s4
christophe34110
transfer pc-> s4
hello I have a dataman s4 I also have the USB connector, I manage to follow the tutorial to connect it to the PC until then all work.i can not send from PC to dataman S4 the file to program my eprom, a person would have a tutorial or explanation to successfully copy from the PC thanks for your help
Re: transfer pc-> s4
Hello christophe34110,
How far did you get? Can you provide the steps you have taken and describe at which point the problem occurs, I will then try to help.
If you have any further questions please do not hesitate to contact us.
christophe34110
Objet : transfert pc-> s4
Hello so I installed the drivers for xp which is for download on the site, when I connect the s4 it goes to the Dataman software on the pc so all commands are functional, I click transfer pc / s4 I open the file and nothing more, I made a cheksum and the memory of the s4 is empty.
What type of file are you trying to send? Intel HEX, Binary, other? The file type must be selected on the S4 using the SETUP menu:
Please let me know if the helps or not.
christophe34110
the file is binary it is downloaded after registering rx? simply on the pc
When transferring a binary file you need to specify the end address of that file before it will send.
In order to get this end address you can use the File > Examine file... feature. Take the file length in bytes and using the Windows calculator in Programmer mode, convert this value to HEX and decrease it by 1 (-1).
Input this value into the S4 driver and hit enter and transfer should begin.
If you continue to have problems please try the older version of the S4 driver (v2.16) which I have made available here:
https://www.dropbox.com/s/bj7hg580l4cnx ... 6.zip?dl=0
christophe34110
Hello following several tests, it is impossible to transfer data from the pc to the s4
Maybe who will have a very specific cord or maybe a specialized Windows, I am a little lost I have all the hardware without being able to make it work
Please make sure that your serial cable has the correct pinout. It should be a "null modem" cable.
S4 Serial Cable pinout
DB9 1 2 3 4 5 6 7 8 9
DB25 8 3 2 20 7 6 4 5 22
You can purchase a suitable cable from our website here:
https://www.dataman.com/s3-s4-serial-cable.html
Please check the Preferences > Port parameters to make sure the correct serial port number is selected.
You will know when you have communication with the PC as the S4 display will be echoed on the S4 driver terminal when it is powered off/on.
christophe34110
Hello I come back to you, after receiving my cable I plugged in my s4 Nizon appeared to see the photos, I do not understand it is that I would like to transfer files from the PC to the s4 And be able to find them to burn them on a eprom.
I would like to know if we must first transfer them to the train and then burn them or if we can make the PC directly in the eprom
thank you
thank you
The procedure depends on how and where your data is located. If it is on a master chip then you can copy the contents into the S4 user RAM and then program it onto a new device. Or, your data could be in the form of a HEX or BINARY file on your PC, in which case you would need to use the S4 driver software and a 25 to 9 pin serial cable (and possibly a (USB to serial) adaptor if your PC/laptop does not have a serial port).
Once you have the S4 driver installed and the necessary cables it is just a matter of choosing the transfer option you need: Choosing the data file and transferring it to the S4:
Once the transfer is complete and you have the correct device selected on the S4 (FUNC > PROM) it is just a matter of hitting the BURN key.
If you get stuck on any specific step then please let me know and I will try to help.
