Programming ATF16V8 no longer works in v3.70
mypinballs
Postby mypinballs » 22 Oct 2021 12:14
As titled after upgrading to v3.70 the programming of ics like Atmel ATF16V8 etc ics no longer works.
The error mentioned is: Unexpected Error 1 Contact Manufacturer of programmer
Screenshot also attached.
I've had to go back to v3.61
mypinballs
Re: Programming ATF16V8 no longer works in v3.70
Postby mypinballs » 25 Oct 2021 16:13
Any reply on whether this can be fixed soon?
Postby Dataman (Neil Parker) » 26 Oct 2021 08:47
Apologies for the delay in responding. Can you confirm that the programmer model is the Dataman-40Pro and can you also confirm the result of the "Selftest..." from the Programmer menu using the diagnostic pod?
mypinballs
Postby mypinballs » 28 Oct 2021 14:57
Yes the programmer is a 40 Pro (upgraded from a MEM Pro) serial 578-03481
I will run the diagnostic test thing but i know these ics program fine in the earlier software as i using 3.61 again and its working fine.
Postby Dataman (Neil Parker) » 29 Oct 2021 10:22
We have improved the code for the mentioned device.
URL: https://www.dataman.com/mwdownloads/dow ... nk/id/202/
Version: 3.71h/10.2021
Sorry for this inconvenience.
mypinballs
Postby mypinballs » 29 Oct 2021 10:42
Excellent :)
Return to “Dataman 40Pro”
