S6 - PIC12F629 Original hex different than written hex?
Topics related to the Dataman S6
mektrix5000
Postby mektrix5000 » 30 Nov 2024 22:29
I'm attempting to write a hex file using the S6 program PIC12F629(DIP8). The written CRC hex file doesn't match the original hex file. I noticed the original hex file contains FFFF in the unwritten/empty fields but the written hex contains 3FFF instead. Attached screenshots of the hex views from Dataman and the log file.
The programmed PIC isn't running correctly so I want to eliminate this as being a potential issue. I've used the same programmer and PIC12F529 Device / Project on other hex files so I'm not sure if there is something i need to edit on this particular hex file. I would've attached the hex file to this post but the forum doesn't allow the *.hex file extension. :)
Thank you in advance, cheers.
Re: S6 - PIC12F629 Original hex different than written hex?
Postby Dataman (Neil Parker) » 02 Dec 2024 09:22
Hello mektrix5000,
The values seen in the buffer are the default blank states of the two devices based on their organisation:
PIC12F629
Organisation: 400h (x14 bit)
Default blank state: 3FFF
PIC12F529
Organisation: 600h (x12 bit)
Default blank state: 0FFF
In general, when working with PIC devices it is a good idea to read a blank device into the buffer before loading your hex file. This way any gaps in your file will have the correct blank state in the buffer.
mektrix5000
Postby mektrix5000 » 02 Dec 2024 16:24
Hello Neil,
Thank you very much for the reply with that helpful information. I'll try that method and report back with my findings.
Return to “Dataman S6”
