AT45DB011B
chris
AT45DB011B
Postby chris » 02 Oct 2014 14:49
I'm trying to program AT45DB011B throught 48PRO2 programmer but got veryfing issue.
I'm using SOIC8 and use a SOIC to ZIF convertor.
I load data to write in buffer then click on program. The programation is ok but I got problem during verifying. Some data in FLASH are different compared to buffer (around 45 bytes).
Am I doing something wrong? Could you help me?
Thank you,
Re: AT45DB011B
Postby Dataman (Neil Parker) » 02 Oct 2014 15:00
Hello Chris,
Did you see the information we provide in the software under the "Device info" section for this device?
General Info:
In case of unreliable work with this device connect 22nF-100nF multilayer capacitor (that meets the EIA X7R or Z5U specification) between VCC and GND pins.
Pins assignment:
VCC = 6
GND = 7
Please apply the bypass capacitor to the adaptor and let me know if the situation does not improve.
chris
Re: AT45DB011B
Postby chris » 02 Oct 2014 15:17
Hi Neil,
It works perfectly. Really thank you .
